C cyleong Known Member Senior Member Jan 17, 2008 #41 my right radiator fan kong....can use v6 punye motor fan or not? can fit ah? btw im using eterna v6tt.... danz.... radiator there got 2 fans. which one? previous mine kong, i use GTO one... is the same.. rm50 onli halfcut shop... 4 wires one
DanzEterna Moderator Moderator Senior Member Jan 17, 2008 #42 mine when facing engine its on the left side, that means its the radiator fan kan......the right fan is aircond....but ori v6 motor strong ah?
L lkk Known Member Senior Member Jan 18, 2008 #45 DanzEterna said: bro..u looking for comfort or sports? Click to expand... looking 4 comfort bro .... thanks in advance
stevenV6 1,000 RPM Senior Member Jan 20, 2008 #46 if looking for comfort,better go for eibach spring.......
L lkk Known Member Senior Member Jan 20, 2008 #47 thanks 4 the advise bro...u also using eibach? sum1 said eibach vr bumpy wor...is that true? thanks in advance
DanzEterna Moderator Moderator Senior Member Jan 21, 2008 #48 change your absorbers to koni la.... or pergi kedai half cut & get eterna springs
takata69 Known Member Senior Member Jan 22, 2008 #49 DanzEterna said: change your absorbers to koni la.... or pergi kedai half cut & get eterna springs Click to expand... what is the diff between eterna springs & perdana springs?? :hmmmm:
stevenV6 1,000 RPM Senior Member Jan 22, 2008 #51 i agree with danz too.....match spring with koni absorber.......comfort & performance wise all ada......kekek.......hehhe
