Perdana V6 - reliable experienced mechanics
Hi, I have some problems with my Perdana V6 (y2000). (1) Temperature seems to show overheating for no clear reason - it moves from middle to high and back to middle frequently even only for short drive. (2) engine oil leaking. Can anyone recommend reliable & experienced mechanics in Subang Jaya or Puchong? Thanks. Hui
I have the same problem ....which i cant solve till today... changed new gearbox, did full overhaul around 1n half years back ...god knows whats the problem ....some say it might be the head gasket is slightly bend already...
if you will like u can send ur car to millenium motorsport in sunway.... i can give u the guy contact number....
try checking your radiator motor fan....might not be spinning fast enuf...
2nd, when was the last time u flushed your radiator? use toyota radiator coolant (RED), changed radiator cap recently?
3rd. check thermosthat.
4th. check water pump & belting.
