Perdana Oil Temp Guage for AT Gearbox
Hey danz i see in google they say cucuk at the ATF oil pan and if cucuk on the return line the sensor adaptor usually they sell outside is very big in diameter for the ATF hose
No answers? I ran across this and might as well share it here.
What do u guys think?
http://www.diyautoftw.com/content.php?1572-Joel-s-DIY-Budget-Oil-Temp-Gauge-by-JDwhiteWRX&
That's a bloody good DIY! If you buy this kit get me one too! I'll pass you the $ before hand
Actually which is best place, as different place will should different results....:hmmmm:
depends on what u want to know...
pre-cooled temp (install at oil cooler inlet)
or
post-cooled temp (install at oil cooler outlet)
or
just current oil temp in the oil pan..... (install at the oil pan)
if me personally prefer at post-cooled temp....so if the reading shoot high even after passing oil cooler...that means the gotta slow down to avoid transmission overheating...
That temp meter is about RM26.50. Cheap and nicer looking than Defi gauges imo. ahhaha
What i'm worried about is the way he held the sensor, silicone will slide out after sometime in my experience.
And mine wasn't even 100 Celsius.
And I want to know the current temperature of the transmission, where do u guys thing I should put in?
Can try those epoxy glue?
