Original Toyota spare part prices
mamatAE111
Trying to start a thread that compares ori spare parts prices, and where to buy them.
The car is getting older (ae111 blacktop) and parts need replacing. Hope can get info on the parts prices from other forummers who have bought them before.
Hope every one can share the information so we can all become better consumers.
Recently bought:
Front brake pads 04465-14390 (celica ST205gt4/Supra MA70/JZA80) RM300
Rubber Seal PVC valve 90480-18001 (SXV10/AE80/AE92/AE101...) RM13
Oil cap Levin 12180-46010 (MCV20 VC10 JZA80) RM26
Oxygen Sensor 89465-19685 RM440
Fuel filter 23300-19285 RM100
Air filter blacktop RM70
Valve Cover Gasket 11213-16021 RM38
Engine Mounting ReaR MT 12371-15241 AE111 AE101 RM130
Engine Mounting Front MT 12361-15181 AE111 AE101 RM75
Shop:Fortune Auto Parts Supply, Taman Paramount P.J (03-78771780)
Just sharing
Car model is not that old but here is the list of spare parts for Toyota Corolla Altis 9th Gen (ZZE122) from SC, take note that this is not the latest price (info found back in 2009) but you can take it as a reference / benchmark / guide / comparision
*some parts can be used for Altis 10th Gen (ZZE142), MR-S (ZZW30), Celica 7th Gen (ZZT230/231), etc.
I will put this thread as sticky for others easier to refer in the future.
Format used will be as below:
[>No] [Description] [Part No] [Price]
>1 [All] Accelerator Cable 78180-02190 56.65
>2 [All] Air Box / Resonator 17893-64080 160.70
>3 [All] Air Filter 17801-22020 93.34
>4 [All] Air Filter Assy 17700-22120 822.05
>5 [A/Filter to Throttle Body] Air Filter Duct 17881-0D040
>36.15
>6 [All] Air Filter Flow Meter 22204-22010 403.40
>7 [All] Air Filter Pick Up Pipe 17751-21070 149.05
>8 [At Steering Wheel] Airbag Drivers side 45130-02150-E0 915.10
>9 [Front] Airbag Impact Sensor LH 89174-19045 394.25
>10 [Front] Airbag Impact Sensor RH 89173-19235 394.25
>11 [All] Airbag Passenger side 73960-12030 4420.05
>12 [At Steering Wheel] Airbag Rotary Coupling 84306-02050
>142.45
>13 [Centre] Airbag Sensor 89170-12380 3656.75
>14 [All] Alternator 27020-0D100-LP 1172.30
>15 [Also for A/C,P/Strg.,W/pump] Alternator Belt 90080-91202
>77.65
>16 [All] Alternator Pulley 27411-50050-LP 36.55
>17 [All] Armrest Centre Rear 72830-02030-D4LP 0.00
>18 [At Dashboard Ctr. Panel lower] Ashtray/Cig Assy
>74102-02040-B0 105.45
>19 [At Console Ctr. rear] -- as above -- 74109-02030-A0 11.90
>20 [All] Battery Tray 74431-12020-LP 6.75
>21 [All] Bonnet 53301-12880 2284.20
>22 [All] Bonnet Hinge LH 53420-12330 19.80
>23 [All] Bonnet Hinge RH 53410-12410 19.80
>24 [All] Bonnet Insulation 53341-12150 370.05
>25 [8 pcs./veh.] Bonnet Insulation Clip 90467-08124 5.20
>26 [All] Bonnet Lndg Cushion 90541-15025 8.50
>27 [All] Bonnet Lock 53510-02100 45.35
>28 [All] Bonnet Lock Stud Plate 53208-12500 34.05
>29 [All] Bonnet Pull Cable 53630-02040 18.35
>30 [All] Bonnet Release Handle 53601-52010-A0 99.20
>31 [All] Bonnet Stand 53440-12010 5.90
>32 [All] Bonnet Stand Retainer 53452-02060 1.90
>33 [Front] Bonnet Weatherstrip 53381-02040 8.15
>34 [All] Boot Carpet 64771-02130-LP 134.65
>35 [All] Boot Extractor Vent 62940-33040 182.10
>36 [Frt. of Boot] Boot Side Trim 64727-02010 35.05
>37 [All] Boot Side Trim LH 64720-02010-C0 74.00
>38 [All] Boot Side Trim RH 64710-02010-C0 74.00
>39 [T] Boot/Tailgate Emblem 90975-02009-LP 17.05
>40 [All] Boot/Tgate Int Lamp Switch 84231-12130 47.50
>41 [All] Bootfloor 58311-02902 1023.35
>42 [Lower section] Bootfloor Front X member 57605-12180
>0.00
>43 [Upper section] -- as above -- 57661-12010 150.80
>44 [All] Bootfloor Front Extension 58211-12919 0.00
>45 [All] Bootfloor Side Extension LH 58314-12300-1 50.25
>46 [All] Bootfloor Side Extension RH 58313-12300-1 50.25
>47 [All] Bootlid 64401-1A820 1071.20
>48 [COROLLA] Bootlid Badge 75442-02040 16.60
>49 [1.8 / 1.6] -- as above -- 75443-1A790 43.50
>50 [ALTIS] -- as above -- 75444-02090 18.70
>51 [E] -- as above -- 75444-02140-LP 10.10
>52 [VVT-i] -- as above -- 75444-02160-LP 11.75
>53 [All] Bootlid Cushion LH 64456-02010 12.20
>54 [All] Bootlid Cushion RH 64455-02010 12.20
>55 [Licence Lamp cover] Bootlid Finisher 76811-12660 255.75
>56 [LH & RH same] Bootlid Hinge 64503-12150 24.20
>57 [LH & RH same] Bootlid Hinge Support 64511-12270 16.05
>58 [All] Bootlid Lock 64610-02050 36.20
>59 [All] Bootlid Lock Cylinder 69055-02030 73.25
>60 [All] Bootlid Release Cable 64607-02060 32.90
>61 [All] Bootlid Release Handle Inner 64606-12060 222.05
>62 [All] Bootlid Striker 64621-12070 38.10
>63 [All] Bootlid Torsion Bar LH 64532-02040-1 32.20
>64 [All] Bootlid Torsion Bar RH 64531-02040-1 32.20
>65 [All] Bottom Ball Joint Front 43330-19115 256.80
>66 [All] Brake ABS ECU 89540-12570 4984.80
>67 [All] Brake ABS Modulator 44050-12122 9853.55
>68 [All] Brake ABS Modulator Brkt 44590-12060 0.00
>69 [All] Brake ABS Sensor LHF 89543-12070 572.00
>70 [All] Brake ABS Sensor Rear 89544-12010 572.00
>71 [All] Brake ABS Sensor RHF 89542-12070 572.00
>72 [All] Brake Booster 44610-02110 348.15
>73 [All] Brake Caliper Front LH 47750-12490 1278.55
>74 [All] Brake Caliper Front RH 47730-12490 1278.55
>75 [All] Brake Caliper LHR 47750-12500 984.40
>76 [All] Brake Caliper RHR 47730-12500 984.40
>77 [All] Brake Disc Front 43512-12650 602.90
>78 [All] Brake Disc Rear 42431-12210 545.75
>79 [All] Brake Flexible Hose LHF 90080-94107 47.15
>80 [All] Brake Flexible Hose Rear 90080-94112 30.95
>81 [All] Brake Flexible Hose RHF 90080-94106 47.15
>82 [All] Brake Master Cylinder Assy 47201-02190 305.20
>83 [All] Brake Pad Set Front 04465-12581 325.90
>84 [All] Brake Pad Set Rear 04466-20090 223.30
>85 [All] Brake Pedal 47101-12600 0.00
>86 [All] Brk Master Cyl Container Cap 47230-04040 12.65
>87 [Outer] Bulb Holder Rear 81555-02120 15.85
>88 [Reverse lamp] -- as above -- 90069-81017 9.65
>89 [Behind Rear Seat] Bulkhead Rear Trim 64271-02050-C0 81.85
>90 [All] Bumper Bracket LHF 53274-12060-83 6.75
>91 [All] Bumper Bracket RHF 53273-12060-83 6.75
>92 [Side] Bumper Bracket RHR 52197-12080 9.45
>93 [Side] -- as above -- 52198-12080 14.25
>94 [Frt. Bumper side] Bumper Clips 90189-09002 1.75
>95 [Frt. & Rr. Bumpers] -- as above -- 90467-09093 5.01
>96 [All] Bumper Front Cover 52119-02909 643.50
>97 [All] Bumper Front Side Retainer LH 52116-12360 60.50
>98 [All] Bumper Front Side Retainer RH 52115-12400 60.50
>99 [LH & RH] Bumper Rear Bracket 52181-02030 14.05
>100 [All] Bumper Rear Cover 52159-02904 700.85
>101 [All] Bumper Rear Side Seal LH 52592-12070 48.45
>102 [All] Bumper Rear Side Seal RH 52591-12150 48.45
>103 [All] Bumper Reinforcement Front 52021-12200 403.10
>104 [Side support] Bumper Retainer/Guide Rear LH 52156-02030
>14.35
>105 [Side support] Bumper Retainer/Guide Rear RH 52155-02040
>14.35
>106 [Inner] C.V. Joint 43403-12040 1004.00
>107 [Frt. of Engine] Camshaft 13501-22060 951.75
>108 [Rr. of Engine] -- as above -- 13502-22010 1010.65
>109 [All] Carpet Passenger Area 58510-02260-A0LP 165.55
>110 [All] Centre Pillar Inner LH 61344-12190 104.60
>111 [All] Centre Pillar Inner RH 61343-12190 104.60
>112 [All] Centre Pillar Lower Trim LH 62414-02061-A0 118.70
>113 [All] Centre Pillar Lower Trim RH 62413-02061-A0 138.60
>114 [All] Centre Pillar Upper Trim LH 62412-02040-A0 34.50
>115 [All] Centre Pillar Upper Trim RH 62411-02040-A0 34.50
>116 [All] Chassis Member Assembly LHF 57102-12810 2130.85
>117 [All] Chassis Member Assembly RHF 57101-12890 2726.25
>118 [All] Chassis Member Extension Fr LH 57114-12160 0.00
>119 [All] Chassis Member Extension Fr RH 57113-12190 0.00
>120 [All] Chassis Member Extension Rr LH 57616-02905 0.00
>121 [All] Chassis Member Extension Rr RH 57615-02906 0.00
>122 [All] Chassis Member Rear LH 57602-1A340 837.95
>123 [All] Chassis Member Rear RH 57601-1A440 825.75
>124 [All] Cigar Lighter Assy 85500-12240 78.70
>125 [All] Connecting Rod 13201-09140 0.00
>126 [All] Connecting Rod Bearing 13041-22023-01 18.00
>127 [All] Console Centre 58901-02070-A0 908.10
>128 [Upper Panel] Console Centre Front Section 58821-02050-B0
>22.50
>129 [All] Cooling Fan Cover 16711-0D040 0.00
>130 [All] Cooling Fan Motor 16363-23020 395.35
>131 [All] Cover Seat Back LHF 71074-02330-D4LP 0.00
>132 [All] Cover Seat Back LHR 71078-02140-D4LP 0.00
>133 [All] Cover Seat Back RHF 71073-02700-D4LP 0.00
>134 [All] Cover Seat Back RHR 71077-02260-D4LP 0.00
>135 [All] Cover Seat Cushion LHF 71072-02470-D4LP 0.00
>136 [All] Cover Seat Cushion Rear 71075-02210-A4LP 875.20
>137 [All] Cover Seat Cushion RHF 71071-02400-D4LP 343.00
>138 [All] Cowl Panel 55700-1A390 882.35
>139 [All] Cowl Panel Grille Clip 90467-06133-C0 6.60
>140 [All] Cowl Panel Grille LH 55709-02010 71.25
>141 [All] Cowl Panel Grille RH 55708-02090 73.00
>142 [All] Crankshaft 13401-22030 2055.00
>143 [All] Crankshaft Bearing 11701-22010-01 22.20
>144 [Upper] Crash Pad 55302-02050-E0 1117.25
>145 [All] Crossmember Front 57104-12110 548.85
>146 [All] Crossmember Rear 57606-12130 0.00
>147 [All] CV Boot Kit Inner & Outer 04438-12590 298.20
>148 [All] Cylinder Head 11101-22070 3625.10
>149 [All] Dashboard Centre Panel 55420-02090-B0 201.85
>150 [All] Dashboard Panel 55303-02061-A0 265.65
>151 [RH] Dashboard Panel Storage Tray 55441-02010-A0 17.45
>152 [Coin Box (RH)] -- as above -- 55441-20140-A0 34.35
>153 [All] Dashboard Panel Supt Carrier 55330-12390 0.00
>154 [All] Dashboard Panel Vent Centre 55406-12320-E0 505.05
>155 [All] Dashboard Panel Vent LH 55650-12270-E0 195.10
>156 [All] Dashboard Panel Vent RH 55670-12300-E0 195.10
>157 [RH] Dashboard Switch Panel 84656-12100-A0 10.05
>158 [All] Door CDL Actuator LHF 69120-12070 90.05
>159 [All] Door CDL Actuator LHR 69140-12040 290.05
>160 [All] Door CDL Actuator RHF 69110-12070 290.05
>161 [All] Door CDL Actuator RHR 69130-12040 290.05
>162 [All] Door Check Strap LHF 68620-12090 209.10
>163 [All] Door Check Strap LHR 68640-12040 209.10
>164 [All] Door Check Strap RHF 68610-12160 209.10
>165 [All] Door Check Strap RHR 68630-12070 209.10
>166 [All] Door Front Hinge Lower LH 68740-52010 99.50
>167 [All] Door Front Hinge Lower RH 68730-52010 99.50
>168 [All] Door Front Hinge Upper LH 68720-12150 28.70
>169 [All] Door Front Hinge Upper RH 68710-12150 28.70
>170 [All] Door Front LH 67002-1A630 1261.85
>171 [All] Door Front RH 67001-1A670 1261.65
>172 [All] Door Glass Run Felt LHF 68151-02050 46.10
>173 [All] Door Glass Run Felt LHR 68152-02050 39.80
>174 [All] Door Glass Run Felt RHF 68141-02060 45.65
>175 [All] Door Glass Run Felt RHR 68142-02050 39.80
>176 [Lock cylinder cover] Door Handle Outer Bezel Front
>69217-42010 21.50
>177 [All] Door Handle Outer Bezel Rear 69227-12070 23.55
>178 [Frt. & Rr. Doors] Door Inner Release Handle LH 69206-12200-A0
>97.85
>179 [Frt. & Rr. Doors] Door Inner Release Handle RH 69205-12200-A0
>97.85
>180 [All] Door Lock Cylinder LH 69052-02030 66.70
>181 [All] Door Lock Cylinder RH 69051-02040 66.70
>182 [All] Door Lock LHF 69040-12530 699.10
>183 [All] Door Lock LHR 69060-12350 699.10
>184 [All] Door Lock RHF 69030-12510 699.10
>185 [All] Door Lock RHR 69050-12350 699.10
>186 [All] Door Lower Moulding LHF 75732-02900-LP 16.85
>187 [All] Door Lower Moulding LHR 75742-02900-LP 12.90
>188 [All] Door Lower Moulding RHF 75731-02900-LP 16.85
>189 [All] Door Lower Moulding RHR 75741-02900-LP 12.90
>190 [All] Door Mirror Glass LH 87961-02130 25.75
>191 [All] Door Mirror Glass RH 87931-02130 25.75
>192 [All] Door Mirror LHF 87940-02210 403.60
>193 [All] Door Mirror RHF 87910-02210 403.60
>194 [Frt. Door] Door Outer Handle Support LH 69202-42010
>200.00
>195 [Rr. Door] -- as above -- 69204-12010 167.05
>196 [Frt. Door] Door Outer Handle Support RH 69201-42010
>200.00
>197 [Rr. Door] -- as above -- 69203-12010 167.05
>198 [All Doors] Door Outer Release Handle 69211-12230 249.05
>199 [Fr.P/Wdw.Sw. Finish.] Door Pull Insert LH 74232-02140-A0
>41.50
>200 [Rr.P/Wdw.Sw. Finish.] -- as above -- 74272-02010-A0 35.05
>201 [Fr.P/Wdw.Sw. Finish.] Door Pull Insert RH 74231-02140-A0
>41.50
>202 [Rr.P/Wdw.Sw. Finish.] -- as above -- 74271-02010-A0 36.65
>203 [All] Door Qtr Glass W/Strip LHR 68189-12280 89.20
>204 [All] Door Qtr Glass W/Strip RHR 68188-12280 88.20
>205 [All] Door Quarter Glass LHR 68124-02050-LP 15.49
>206 [All] Door Quarter Glass RHR 68123-02050-LP 15.49
>207 [All] Door Rear Hinge Lower LH 68780-52030 99.80
>208 [All] Door Rear Hinge Lower RH 68770-52030 89.80
>209 [All] Door Rear Hinge Upper LH 68760-52011 99.50
>210 [All] Door Rear Hinge Upper RH 68750-52011 99.50
>211 [All] Door Rear LH 67004-12890 1305.80
>212 [All] Door Rear RH 67003-1A010 1503.90
>213 [All] Door Regulator Motor LHF 85720-12210 648.65
>214 [All] Door Regulator Motor LHR 85710-12250 648.65
>215 [All] Door Regulator Motor RHF 85710-12190 648.65
>216 [All] Door Regulator Motor RHR 85720-12250 648.65
>217 [Lwr. Rr. of Door] Door Run Channel LHF 67404-12200 59.15
>218 [All] Door Run Channel LHR 67408-12260 177.05
>219 [Lwr. Rr. of Door] Door Run Channel RHF 67403-12200 59.15
>220 [All] Door Run Channel RHR 67407-12260 177.05
>221 [All Doors] Door Striker 69410-20110 51.20
>222 [All] Door Trimboard Finisher LHF 67660-02110-D1LP
>763.00
>223 [All] Door Trimboard Finisher LHR 67640-02620-D1LP
>628.35
>224 [All] Door Trimboard Finisher RHF 67650-02100-D1LP
>763.00
>225 [All] Door Trimboard Finisher RHR 67630-02620-D1LP
>628.35
>226 [All] Door Warning Lamp Front 81230-02010 14.75
>227 [All] Door Window Glass LHF 68102-02070-LP 75.12
>228 [All] Door Window Glass LHR 68114-02060-LP 55.01
>229 [All] Door Window Glass RHF 68101-02070-LP 75.12
>230 [All] Door Window Glass RHR 68113-02060-LP 55.01
>231 [All] Door Window Regulator LHF 69802-12190 313.10
>232 [All] Door Window Regulator LHR 69804-12140 251.10
>233 [All] Door Window Regulator RHF 69801-12190 313.10
>234 [All] Door Window Regulator RHR 69803-12140 251.10
>235 [All] Doorskin Front LH 67112-12660 212.50
>236 [All] Doorskin Front RH 67111-12670 212.50
>237 [All] Doorskin Rear LH 67114-12270 0.00
>238 [All] Doorskin Rear RH 67113-12270 0.00
>239 [All] Dr Mirror Inner Trim Cover LH 67492-12480 63.95
>240 [All] Dr Mirror Inner Trim Cover RH 67491-12480 63.95
>241 [All] Drive & Ring Gear Plate 32101-12090 524.00
>242 [All] Driveshaft LHF 43420-02200 1439.25
>243 [All] Driveshaft RHF 43410-02180 1519.80
>244 [All] ECU Engine 89661-02880-LP 1458.60
>245 [All] ECU Reverse Sensor 89340-0B010-LP 568.30
>246 [RHF] Electric Window Control Panel 84820-02050 331.55
>247 [LHF & Rear Doors] Electric Window Switch 84810-02030
>20.65
>248 [Partial] Engine 19000-0D090 0.00
>249 [All] Engine Block 11410-29057 5257.70
>250 [Top (with Toyota & VVTi logo)] Engine Cover 11212-0D010
>43.60
>251 [All] Engine Gasket Top Set 04112-0D070 1171.95
>252 [All] Engine Inlet Manifold 17120-22040 1153.85
>253 [All] Engine Inlet Manifold Gasket 17171-22030 13.25
>254 [All] Engine Lower Splash Shield LH 51442-02101 126.20
>255 [All] Engine Lower Splash Shield RH 51441-02061 134.65
>256 [Front] Engine Mounting Bracket 12311-0D040 26.40
>257 [Rear] -- as above -- 12321-0D070 50.20
>258 [All] Engine Mounting Bracket RH 12316-22100 141.15
>259 [All] Engine Mounting Front 12361-0D040 123.90
>260 [All] Engine Mounting LH 12372-0D050 0.00
>261 [All] Engine Mounting Rear 12371-0D050 161.40
>262 [All] Engine Mounting RH 12362-22090 0.00
>263 [All] Engine Oil Sump 12101-0D030 0.00
>264 [All] Engine Overhaul Gasket 04111-0D070 0.00
>265 [All] Engine Partition Panel 55101-19025 0.00
>266 [Crankshaft] Engine Pulley(s) 13470-22040 669.60
>267 [All] Engine Supp Member 51204-12130 301.15
>268 [All] Exhaust Front Mounting 17565-21030 46.40
>269 [All] Exhaust Front Pipe 17410-0D060-LP 474.00
>270 [All] Exhaust Heatshield Rear 58327-12160 201.05
>271 [All] Exhaust Manifold 17104-22050 720.95
>272 [Upper] Exhaust Manifold Cover 17167-22040 328.05
>273 [Lower] -- as above -- 17168-0D020 63.10
>274 [Ex. Manifold to Cyl. Head] Exhaust Manifold Gasket
>17173-22010 58.25
>275 [Ex. Manifold to Frt. Pipe] -- as above -- 17451-22070
>103.65
>276 [Frt. & Rr. of Silencer] Exhaust Rear Mounting 17565-21040
>58.90
>277 [All] Exhaust Silencer 17430-0D080-LP 291.10
>278 [All] Exhaust Valve 13715-22040 20.40
>279 [All] Fan Blade (Radiator) 16361-0D060 102.00
>280 [Between Frt Fender & Frt Door] Fender End Plate LH
>53828-12050 106.10
>281 [Between Frt Fender & Frt Door] Fender End Plate RH
>53827-12050 106.10
>282 [All] Fender LH 53812-1H020 455.35
>283 [All] Fender Liner LHF 53876-12280 214.00
>284 [All] Fender Liner RHF 53875-12290 214.00
>285 [All] Fender RH 53811-1H140 455.35
>286 [All] Fender Signal Lamp 81731-02040 17.90
>287 [RH] Floor Pan Crossmember Front 57451-12191 33.50
>288 [LH] -- as above -- 57452-12041 34.80
>289 [All] Floor Pan Front 58111-12281 358.95
>290 [All] Floor Pan Support Member LH 57402-12570 310.20
>291 [All] Floor Pan Support Member RH 57401-12570 383.35
>292 [Frt. RH] Fog Lamp Finisher 52127-20120 16.60
>293 [Frt. LH] -- as above -- 52128-20080 16.60
>294 [All] Fog Lamp Front LH 81221-20440 265.70
>295 [All] Fog Lamp Front RH 81211-20450 265.70
>296 [All] Footrest 58191-12120 106.10
>297 [All] Front Panel Assembly 53201-1A240 1480.90
>298 [All] Front Pillar Inner LH 61024-12300 140.50
>299 [All] Front Pillar Inner RH 61023-12300 140.50
>300 [All] Front Pillar Lower Trim LH 62112-02060-A0 55.10
>301 [All] Front Pillar Lower Trim RH 62111-02060-A0 55.25
>302 [All] Front Pillar Outer LH 61132-12630-1 152.35
>303 [All] Front Pillar Outer RH 61131-12630-1 164.00
>304 [All] Front Pillar Outer Trim LH 60118-12010 46.90
>305 [All] Front Pillar Outer Trim RH 60117-12010 43.20
>306 [All] Front Pillar Reinforcement LH 61109-12220 242.50
>307 [All] Front Pillar Reinforcement RH 61108-12230 243.90
>308 [All] Front Pillar Trim LH 62212-02050-A0 42.65
>309 [All] Front Pillar Trim RH 62211-02050-A0 42.65
>310 [All] Fuel Charcoal Filter 77740-02110 230.90
>311 [All] Fuel Delivery Pipe 23807-22030 280.70
>312 [All] Fuel Filler Cap 77310-48010 115.20
>313 [All] Fuel Filler Flap 77350-12450 125.05
>314 [Filler pipe outer shield] Fuel Filler Housing 77291-12150
>65.45
>315 [All] Fuel Filler Pipe Protection 77277-12170 115.05
>316 [in Fuel Tank] Fuel Filter 23300-21010 118.30
>317 [All] Fuel Flap Release Cable 77035-02050 35.20
>318 [Lock retainer] Fuel Flap Release Mechanism 77377-12050
>13.20
>319 [All] Fuel Injector 23209-0D030 545.25
>320 [with Fuel Pump in Fuel Tank] Fuel Pressure Regulator Assy
>23280-22010 290.60
>321 [All] Fuel Pump 23221-22030 1035.95
>322 [All] Fuel Supply Pipe 77251-12660-LP 61.00
>323 [All] Fuel Tank 77001-02110-LP 0.00
>324 [All] Fuel Tank Filler Hose 77213-32070 102.05
>325 [All] Fuel Tank Filler Pipe 77201-02110 314.00
>326 [All] Fuel Tank Float Unit 83320-12640 122.15
>327 [All] Fuel Tank Strap LH 77602-12180 22.05
>328 [All] Fuel Tank Strap RH 77601-12230 18.60
>329 [All] Gasket Cylinder Head 11115-22040 83.35
>330 [All] Gasket Rocker Cover 11213-0D020 90.50
>331 [Transmission Control] Gear Selector Cable 33820-02300
>127.85
>332 [Parking Lock] -- as above -- 33880-12030 0.00
>333 [Assembly] Gear Shift Lever 33560-12100 0.00
>334 [Gear Position Indicator] Gear Shift Lever Gaiter/Cover
>35971-12480 67.40
>335 [All] Gear Shift Lever Knob 33542-12310-E0 216.25
>336 [All] Glove Box Lid Lock 55560-12120-A0 48.80
>337 [All] Glove Compartment Assy 55550-02041-A0 127.35
>338 [Console Centre] Glove Compartment Lid 58906-02020-LP 224.40
>339 [T] Grille Badge 75311-02090 18.10
>340 [All] Grille Clips 52161-16010 5.90
>341 [All] Grille Front 53111-02120 471.20
>342 [Front] Handbrake Cable 46410-02060 25.20
>343 [All] Handbrake Cable LH 46430-12400 167.10
>344 [All] Handbrake Cable RH 46420-12490 173.80
>345 [All] Handbrake Lever 46201-02100-E0 121.50
>346 [All] Header Rail 63102-12150 238.00
>347 [All] Headlamp Assy LH 81170-02110 316.55
>348 [All] Headlamp Assy RH 81130-02120 316.55
>349 [12V 51W (Outer)] Headlamp Bulb 90080-81040 48.50
>350 [12V 60W (Inner)] -- as above -- 90080-81041 48.50
>351 [Yellow colour(for turn signal)] -- as above -- 90981-15009
>14.65
>352 [All] Headrest Assy Front 71910-02220-D4LP 291.75
>353 [All] Headrest Assy Rear 71940-02100-D4LP 0.00
>354 [All] High Level/Third Brake Lights 81570-02050-A0 83.85
>355 [High pitched] Horn 86510-33070-LP 26.75
>356 [Low pitched] -- as above -- 86520-02040-LP 25.50
>357 [All] Ignition Coil 90919-02239 254.85
>358 [All] Ignition Starter Switch 84450-52010 202.25
>359 [Fender Signal Lamp] Indicator Bulb Holder Front
>90075-99012 28.45
>360 [All] Inlet Valve 13711-22040 19.45
>361 [Meters complete] Instrument Cluster 83800-02590 1773.15
>362 [All] Instrument Cluster Glass 83852-02590 62.25
>363 [All] Instrument Cluster Surround 55403-02030 53.65
>364 [Below Dashboard] Insulation Inner Bulkhead 55210-02050
>222.30
>365 [Engine compartment] Insulation Outer Bulkhead 55223-12090
>0.00
>366 [LH & RH same] Insulation Quarter Panel 62475-02010 4.60
>367 [All] Interior Lamp 81240-12070-LP 15.55
>368 [Front Doors] Interior Lamp Door Switch 84231-02070 12.15
>369 [Rear Doors] -- as above -- 84231-02090 12.15
>370 [All] Interior Lamp Lens 81241-12070-LP 4.00
>371 [All] Knuckle Arm LHF 43212-19015 674.60
>372 [All] Knuckle Arm RHF 43211-19015 674.60
>373 [All] Lower Dash Panel RH 55045-02060-A0 158.50
>374 [All] Luggage Compartment Lamp 81330-0A010 10.75
>375 [All] Mirror Rear View 87810-0A020-A0 72.05
>376 [All] Mudflap LHF 76622-02080-LP 12.95
>377 [All] Mudflap LHR 76626-02090-LP 12.05
>378 [All] Mudflap RHF 76621-02080-LP 12.95
>379 [All] Mudflap RHR 76625-02090-LP 12.05
>380 [RH] Number Plate Lamp / Lamps 81270-02040-LP 12.85
>381 [LH] -- as above -- 81690-02030-LP 12.85
>382 [RH] Number Plate Lamp Lens 81271-02040-LP 4.90
>383 [LH] -- as above -- 81691-02030-LP 4.90
>384 [All] Number Plate Lamp Socket 81275-12501-LP 7.15
>385 [All] Oil Filter 90915-10003 34.48
>386 [All] Oil Pump 15100-22040 313.15
>387 [All] Oil Sump Strainer 15104-22022 86.75
>388 [All] Parcel Shelf Rear 64101-12780 181.55
>389 [All] Parcel Shelf Rear Trim 64330-02200-A0 131.05
>390 [All] Parcel Shelf Side Support LH 64305-12040 381.05
>391 [All] Parcel Shelf Side Support RH 64304-12040 381.05
>392 [All] PAS Fluid Container 44360-12110 0.00
>393 [All] PAS Fluid Container Cap 44305-28030 55.35
>394 [All] PAS Pump 44320-02060 612.70
>395 [All] PAS Pump Pulley 44311-02090 51.90
>396 [Long (At Reservoir)] PAS Return Pipe 44406-02071 288.50
>397 [Short (At Strg. Rack)] -- as above -- 44416-02040 32.15
>398 [Reservoir to Pump] PAS Supply Hose 44348-02040 95.05
>399 [Pump to Strg. Rack] PAS Supply Pipe 44410-02090 275.85
>400 [Brake] Pedal Support Bracket 55106-12650 0.00
>401 [with Pin] Piston 13101-0D070 157.30
>402 [All] Piston Ring Set 13011-22100 167.45
>403 [All] Position Sensor Crankshaft 90919-05026 249.85
>404 [All] Quarter Inner Rear (Upper) LH 61732-12640-1 121.05
>405 [All] Quarter Inner Rear (Upper) RH 61731-12680-1 121.05
>406 [Lwr. Rr. Corner] Quarter Inner Rr Reinf Lwr LH 61698-02901
>247.80
>407 [Lwr. Rr. Corner] Quarter Inner Rr Reinf Lwr RH 61697-02901
>250.65
>408 [All] Quarter Inner Trim LH 62472-02100-A0 163.25
>409 [All] Quarter Inner Trim RH 62471-02100-A0 163.25
>410 [All] Quarter Panel LH 61602-1E870-1 920.40
>411 [All] Quarter Panel RH 61601-1H140-1 1007.40
>412 [All] R/board Pnl Tread Plate LHF 67914-02050-A0 27.50
>413 [All] R/board Pnl Tread Plate LHR 67918-02040-A0 21.90
>414 [All] R/board Pnl Tread Plate RHF 67913-02050-A0 27.50
>415 [All] R/board Pnl Tread Plate RHR 67917-02040-A0 21.90
>416 [All] Radiator 16400-0D160-LP 579.55
>417 [All] Radiator Bottom Hose 16572-0D090-LP 21.10
>418 [All] Radiator Cap 16401-72091-LP 66.30
>419 [All] Radiator Top Hose 16571-0D100-LP 21.40
>420 [Outer] Rear Lamp Assembly LH 81561-02120 108.70
>421 [Outer] Rear Lamp Assembly RH 81551-02120 108.70
>422 [All] Rear Lamp Pnl Interior Trim LH 64746-02050 51.50
>423 [All] Rear Lamp Pnl Interior Trim RH 64745-02050 51.50
>424 [All] Rear Panel 58307-1A620 337.75
>425 [All] Rear Panel Inner Trim 58387-02030-B0 51.50
>426 [RH] Rear Panel Upper 52552-02010 64.55
>427 [LH] -- as above -- 52553-02010 63.10
>428 [Engine Room LH] Relay Box 82741-12020 239.05
>429 [Engine Room LH] Relay Box Cover 82662-12090 69.30
>430 [At Bootlid] Reverse Lamp LH 81591-02010 64.55
>431 [At Bootlid] Reverse Lamp RH 81581-02010 64.55
>432 [All] Rocker Cover 11201-0D040 3935.20
>433 [All] Rocker Cover Cap 12180-55010 32.90
>434 [All] Roof Grip Handle 74611-12020-A0 52.05
>435 [All] Roof Moulding LH 75556-12100 129.05
>436 [All] Roof Moulding RH 75555-12100 129.05
>437 [All] Roof Panel 63111-12760-1 286.10
>438 [All] Roof Panel Rear Member 63133-12260-1 102.80
>439 [3rd.] Roof Panel Reinforcement 63141-12260 82.55
>440 [1st.& 2nd.] -- as above -- 63143-12100 82.55
>441 [4th.] -- as above -- 63144-12080 82.55
>442 [Outer] Roof Side Member LH 61212-12420-1 98.30
>443 [Inner] -- as above -- 61232-12880 86.15
>444 [All] Roof Side Member Reinf LH 61246-12040 49.80
>445 [All] Roof Side Member Reinf RH 61245-12040 49.80
>446 [Outer] Roof Side Member RH 61211-12420-1 108.75
>447 [Inner] -- as above -- 61231-1A110 86.15
>448 [All] Rooflining 63310-02160-A0 373.65
>449 [All] Rooflining Retainer Clip 90467-05021-A1 3.25
>450 [Outer] Runningboard & Ctr Pillar LH 61312-12380-1 174.00
>451 [Outer] Runningboard & Ctr Pillar RH 61311-12340-1 163.40
>452 [All] Runningboard Outer Trim LH 75852-12061 227.10
>453 [All] Runningboard Outer Trim RH 75851-12091 227.10
>454 [All] Runningboard Panel Inner LH 61404-12030 0.00
>455 [All] Runningboard Panel Inner RH 61403-12030 138.35
>456 [All] Seat Back Assy LHF 71440-02440-D4LP 0.00
>457 [All] Seat Back Assy LHR 71490-02150-D4LP 0.00
>458 [Outer] -- as above -- 71540-02050-D4LP 0.00
>459 [All] Seat Back Assy RHF 71430-02590-D4LP 0.00
>460 [All] Seat Back Assy RHR 71480-02300-D4LP 0.00
>461 [Outer] -- as above -- 71540-02110-D4LP 165.60
>462 [All] Seat Belt Adjuster Front 73200-02020-A0 59.40
>463 [RH] Seat Belt Rear Double Buckle 73470-02080-A0LP
>35.05
>464 [LH] -- as above -- 73480-02090-A0LP 62.20
>465 [All] Seat Belt Reel LHF 73220-02080-A0LP 85.05
>466 [All] Seat Belt Reel Rear 73360-02150-A0LP 115.70
>467 [All] Seat Belt Reel RHF 73210-02110-A0LP 85.05
>468 [All] Seat Belt Stalk LHF 73230-02090-A0LP 16.05
>469 [All] Seat Belt Stalk RHF 73230-02100-A0LP 43.35
>470 [All] Seat Cushion Assy LHF 71420-02400-D4LP 0.00
>471 [All] Seat Cushion Assy RHF 71410-02500-D4LP 0.00
>472 [All] Seat Cushion Rear 71460-02240-D4LP 0.00
>473 [Outer] Seat Slider Assembly LHF 72012-02070 238.95
>474 [Inner] -- as above -- 72022-02070 364.95
>475 [Outer] Seat Slider Assembly RHF 72011-02081 238.95
>476 [Inner] -- as above -- 72021-02080 280.05
>477 [All] Shock Absorber Front LH 48520-02160-LP 194.11
>478 [All] Shock Absorber Front RH 48510-02160-LP 194.11
>479 [All] Shock Absorber Rear 48530-02190-LP 147.21
>480 [RH] Shock Absorber Rear Brkt 58341-12020 201.90
>481 [LH] -- as above -- 58342-12020 186.00
>482 [RH] Shock Absorber Top Mount Rear 48401-32020 85.80
>483 [LH] -- as above -- 48403-32010 85.80
>484 [Upper LH & RH] Side Demister Vent 55961-02030-E0 5.60
>485 [All] Spare Wheel Cover Board 64711-02050-C0 88.90
>486 [All] Spare Wheel Retainer 51900-12190-LP 4.50
>487 [K16R-U11] Spark Plug 90919-01164 8.06
>488 [All] Speaker Rear 86160-02360-LP 272.25
>489 [All] Stabilizer Bar Brkt Front 48824-26210 38.50
>490 [Front] Stabilizer Bar Bush 48815-02060 10.30
>491 [All] Stabilizer Bar Front 48811-02060 162.25
>492 [All] Stabilizer Bar Front Link Rod 48820-47010 271.10
>493 [All] Stabilizer Bar Rear 48812-02100 153.95
>494 [All] Starter Motor 28100-0D070-LP 631.00
>495 [Assembly] Steering Column 45250-1E200 1370.05
>496 [All] Steering Column Cover Complete 45286-02915-E1 35.95
>497 [All] Steering Column Lock 45280-02040 63.25
>498 [All] Steering Column Lower Joint 45260-12460 571.75
>499 [All] Steering Column Lwr Joint Cov 45025-13020 137.10
>500 [Upper main shaft] Steering Column Shaft 45210-42020
>864.05
>501 [Lower shaft] -- as above -- 45221-12290 393.00
>502 [Wipers] Steering Column Switch LH 84652-02210 151.00
>503 [Lightings] Steering Column Switch RH 84140-02090 106.60
>504 [All] Steering Lock Cylinder Assy 69057-02030 85.55
>505 [All] Steering Rack/Box PAS 44250-13021 4320.05
>506 [All] Steering Tie Rod 45503-19255 357.65
>507 [All] Steering Tie Rod End LH 45047-49045 102.55
>508 [All] Steering Tie Rod End RH 45046-49115 102.55
>509 [All] Steering Wheel 45100-02180-E0 3043.45
>510 [All] Sun Visor LH 74320-02130-A1 114.05
>511 [All] Sun Visor RH 74310-02150-A1 86.15
>512 [All] Suspension Arm LHF 48069-12220 670.95
>513 [All] Suspension Arm RHF 48068-12220 670.95
>514 [All] Suspension Crossmember Front 51201-20350 2785.65
>515 [All] Suspension Crossmember Rear 42101-02020 2404.85
>516 [All] Suspension Spring Front 48131-02770-LP 62.33
>517 [All] Suspension Spring Rear 48231-02240-LP 47.62
>518 [All] Suspension Top Mount Front 48609-12440 249.55
>519 [All] Switch Brake Pedal 84340-04010 13.35
>520 [All] Switch Exterior Mirror 84872-02030 49.30
>521 [All] Thermostat 90916-03125 44.50
>522 [All] Throttle Body 22210-22060 2391.85
>523 [All] Throttle Pedal 78120-12340 156.50
>524 [All] Timing Chain 13506-22030 313.55
>525 [All] Timing Chain Cover 11321-22021 459.00
>526 [Camshaft] Timing Chain Sprocket 13050-22011 320.05
>527 [Crankshaft] -- as above -- 13521-22020 28.70
>528 [All] Timing Chain Tensioner 13540-22022 67.65
>529 [All] Torque Convertor 32000-12350 4660.00
>530 [All] Torque Convertor Housing 35105-12060 2940.05
>531 [All] Towing Eye Front 51963-12240 9.85
>532 [RH] Towing Eye Rear 51967-12270 0.00
>533 [LH] -- as above -- 51968-12170 25.75
>534 [All] Transmission Assy (A) 30500-1A680 20138.85
>535 [All] Transmission Case (A) 35104-12270 4460.00
>536 [All] Transmission Oil Pump Assy 35035-20010 871.80
>537 [All] Transmission Sump 35106-12100 213.10
>538 [All] Transmission Sump Gasket 35168-12060 31.75
>539 [All] Valve Body 35410-12691 3840.05
>540 [All] Vehicle Jack 09111-20110-LP 65.10
>541 [All] Vehicle Jack Lever 09113-12020-LP 24.30
>542 [All] Vehicle Jack Retainer 58791-12200 51.70
>543 [All] Vehicle Tool Bag 09120-0A010 12.45
>544 [All] W/screen Washer Pump 85330-10280-LP 36.20
>545 [All] Washer Jet Front 85381-12240 30.45
>546 [All] Water Pump 16100-29175 352.50
>547 [All] Water Pump Pulley 16173-22020 76.30
>548 [Belt] Water Pump Tensioner 16620-22011 630.00
>549 [All] Weather Sheeting Door LHF 67832-02090 16.05
>550 [All] Weather Sheeting Door LHR 67842-02040 15.60
>551 [All] Weather Sheeting Door RHF 67831-02090 16.05
>552 [All] Weather Sheeting Door RHR 67841-02060 15.61
>553 [All] Weatherstrip Bonnet At Rear 53383-12140 43.55
>554 [All] Weatherstrip Boot Aperture 64461-02060 58.60
>555 [All] Weatherstrip Door Aperture LHF 62312-02050-A0 159.80
>556 [All] Weatherstrip Door Aperture LHR 62332-02050-A0 169.80
>557 [All] Weatherstrip Door Aperture RHF 62311-02050-A0 159.80
>558 [All] Weatherstrip Door Aperture RHR 62331-02050-A0 169.80
>559 [All] Weatherstrip Door LHF 67862-02100 46.50
>560 [All] Weatherstrip Door LHR 67872-02050 41.80
>561 [All] Weatherstrip Door RHF 67861-02100 46.50
>562 [All] Weatherstrip Door RHR 67871-02050 41.80
>563 [All] Weatherstrip Inner LHFD Glass 68172-02060-LP 44.90
>564 [All] Weatherstrip Inner LHRD Glass 68174-02050-LP 44.90
>565 [All] Weatherstrip Inner RHFD Glass 68171-02090-LP 44.90
>566 [All] Weatherstrip Inner RHRD Glass 68173-02080-LP 44.90
>567 [All] Weatherstrip Outer LHFD Glass 75720-12730 174.05
>568 [All] Weatherstrip Outer LHRD Glass 75740-12340 174.05
>569 [All] Weatherstrip Outer RHFD Glass 75710-12730 174.05
>570 [All] Weatherstrip Outer RHRD Glass 75730-12250 174.05
>571 [All] Wheel Bearing Front 90363-40066 132.55
>572 [All] Wheel Centre 42603-02110 25.30
>573 [All] Wheel Hub Front 43502-12140 287.05
>574 [with wheel bearing] Wheel Hub Rear 42450-12050 1288.95
>575 [14X6JJ (7-Spokes)] Wheel Rim Alloy 42611-02310-MA 387.56
>576 [All] Wheelhouse Front LH 53702-1A080 588.40
>577 [All] Wheelhouse Front RH 53701-1A130 602.70
>578 [All] Wheelhouse Inner Rear LH 61608-02913 374.00
>579 [All] Wheelhouse Inner Rear RH 61607-02915 0.00
>580 [All] Wheelhouse Outer Rear LH 61632-12370 183.85
>581 [All] Wheelhouse Outer Rear RH 61631-12360 183.25
>582 [Frt. & Rr. W/screen] Windscreen Bonding Kit 56117-12240
>36.40
>583 [Stopper (Frt. & Rr. W/screen)] Windscreen Clip 56115-30100
>5.40
>584 [Laminated (Green)] Windscreen Front 56111-02110-LP 346.77
>585 [All] Windscreen Front Full-Moulding 75533-12490 166.83
>586 [Spacer (Frt. & Rr. W/screen)] Windscreen Front Guides
>56116-22050 5.40
>587 Windscreen Rear 64811-02160-LP 246.95
>588 [All] Windscreen Rear Moulding 75571-12860 142.05
>589 [All] Windscreen Washer Tank 85315-12450-LP 186.00
>590 [All] Windscreen Washer Tube 90446-07001 17.70
>591 [All] Wiper Arm Front LH 85221-02090-LP 53.80
>592 [All] Wiper Arm Front RH 85211-02080-LP 51.00
>593 [All] Wiper Blade LHF 85222-02080-LP 23.50
>594 [All] Wiper Blade RHF 85212-02080-LP 51.00
>595 [Assembly] Wiper Link Rod 85150-1A020-LP 14.75
>596 [All] Wiper Motor Front 85110-1A030-LP 99.46
>597 [All] Wiring Loom Battery Tray LH 82123-02150-LP 27.25
>598 [All] Wiring Loom Centre Floor Pan 82161-02550-LP 289.95
>599 [All] Wiring Loom Dashboard 82146-02840-LP 965.45
>600 [All] Wiring Loom Door LHF 82152-02520-LP 77.70
>601 [LH & RH] Wiring Loom Door Rear 82153-02170-LP 38.30
>602 [All] Wiring Loom Door RHF 82151-02600-LP 116.30
>603 [All] Wiring Loom Engine 82121-02520-LP 870.20
>604 [Engine] Wiring Loom Main 82115-02450-LP 969.50
>605 [All] Wiring Loom Roof 82171-02220-LP 35.15
Toyota Blacktop 4age
13521-16060 crank timing gear (RM55)
13540-16010 tensioner (RM120)
22270-16070 idling valve ISCV (RM610)
Shop : Vanli Auto
---------- Post added at 01:50 AM ---------- 6 hour anti-bump limit - Previous post was at 01:49 AM ----------
Advics Twin Pot brake pad (mr2 sw20) RM165
Aisin Clutch RM120
Aisin Water Pump RM135
CBT Autoparts Penang
---------- Post added at 01:51 AM ---------- 6 hour anti-bump limit - Previous post was at 01:50 AM ----------
Aisin Clutch cover RM170
Oil Control Valve 15330-16020-RM185
Oil Pressure Switch 83520-35030-RM150
Coolant Temperature Sensor 89422-35010-RM130
Cam Pulley VVT 13050-16020-RM720
Radiator Fan Motor Denso 16363-15120-RM155
OEM Coils/Springs - RM55 per pcs
Facebook
