noisy clutch
kurt_629
Hello,
not sure if this belong to here, please help to post to the correct channel.
I have a small car, proton savvy manual.
I did a change of clutch bearing and clutch while it hit 150k.
now at 170k, the clutch is kinda noisy during idle.
once I step the clutch, the noise will go off.
is it that the clutch bearing is gone?
what happen if I don't change the clutch bearing?
will it cause the car to break down or unable to change gear?
labor fee is expensive as I was told not easy to change savvy clutch or its bearing..
Hello,
Sound like the clutch release bearing since you mention step on clutch no sound.....:smokin:
throwout bearing and release bearing dif thing ka?... throwout, i think when pushed in only bising
the input shaft bearing on the other hand should do what you mentioned... (clutch depressed, noise goes away)
Iam with lsm1991,
When we depress the clutch, the bearing will function and rotate the whole clutch assembly without the clutch pad. I believe whether its a pull or push type, its the same concept. Bearing will function when the clutch depress only.
Iam with lsm1991,
I had that problem before, and my mechanic call it release bearing, because don't step is attached, step is release mah.......lol
