NEO CPS-Do neo cps need the anti roll bar?
lordredza
Hello there
need opinion...
i just..install a ultra racing strut bar..and it works perfectly when im taking a corner at 160km-170km
planning to install the anti roll bar...for the rear and front of my car...but
a friend of mine said -no need la the anti roll bar...cps have the lotus-handling-it better waste of money...
so the question is...do neo cps need to the anti roll bar?
regards!
The Neo (as far as I know) already has rear anti-roll bar (ARB). By using a bigger diameter ARB at the rear, it will reduce the roll rate, but it'll also make your car more prone to oversteer. My opinion: If U want to make the car handle better, invest in a set of adjustable absorber instead.
actually my personal opinion, the car suspension setup is good enuf, its ground clearance just nice, wont hit curb when u go over the speed breaker and cornering is sharp and nice. lotus handling is the setting shock and spring to a certain tension to fit for street and race use.
unless u r a hardcore driver...if not the stock setup is good enuf....
---------- Post added at 12:37 AM ---------- 6 hour anti-bump limit - Previous post was at 12:35 AM ----------
adding more struts and bars will make the chassis too stiff...u will have the risk of yr car losing control without u realising it...coz its too stable and u push it exceed the limit it can take....just my personal opinion...
thanks guys..really appreciate it...
---------- Post added at 10:30 AM ---------- 6 hour anti-bump limit - Previous post was at 10:26 AM ----------
mm..im not planning to change my absorber yet... the original absorber is still in best condition...lotus handling ma..hehe
anyway thanks for the advise..
regards!
