K KoNa Known Member Senior Member Feb 12, 2005 #1 as the topic states... can ar?? just change cams?? or wat? pls hel;p yea.. thanx in advance!
O oly 500 RPM Senior Member Feb 12, 2005 #3 can...pls find or pm moppy...he allready change to dohc head...can masuk mivec head also...but must change ecu throttle body,intake and outlet manifold... <_<
A -ArChAng3L- 2,000 RPM Senior Member Feb 13, 2005 #4 you need the whole head lor not only the cams ;)
amad108.. Known Member Senior Member Feb 14, 2005 #5 power increase if do it right, if not it's gonna be worst...
C chiku Known Member Senior Member Feb 22, 2005 #6 B) yeah.. agree wit amad... better find powerful n expert sifu or foreman to run this project... if not the result will dissapointed you... :(
