Mivec gearbox problem
deanengson
From Facebook
I recently did a CJ4A Mivec swap into my ride, its a non-lsd gearbox.
Just now my car came up with this problem..
Hard to engage gear especially 1st gear when on a full stop, and then the gearbox makes some sounds when i fully press the clutch pedal, seems like the clutch isnt pulled completely..
and when i let go of the pedal, the pedal doesnt come up smoothly, it yanks roughly when i let go of it..
need help here :bawling:
to the sound when press the clutch, maybe this is a problem of the clutch bearing.
firstly, it could be a problem from the clutch pump either leaking or not bleeding properly.
secondly, try to check the clutch fork to push the bearing. either position or slip a little gritty
thirdly, maybe the problem of clutch cover. (clutch can not engage)
