mivec ck conversion
faheem182
hello..if i'm planning to convert the campro engine with mivec ck engine,wat's the necessary mod??..i heard it has to put an additional cross member below?
---------- Post added at 01:52 AM ---------- 6 hour anti-bump limit - Previous post was at 01:49 AM ----------
the 1.6 version
same as what day do with gsr ck..
for me no need add cross member. accept if u plan to upgrade more hp and tork..
mivec ck pnp to gen 2 and persona ,satria neo, but saga i not sure, u even can use back the ori undercarriage ....... for gsr ck, the additional cross member is actually swapping ori cross member to gsr ck because the gsr ck gearbox is 4wd,the cross member is specialize to give clearance to the 4wd gearbox....
