D dammahum Oct 7, 2012 #1 car model:daihatsu charade aura is there any DIY method to fix this instead of replacing a new water pump?
spoon civic Known Member Oct 7, 2012 #2 dammahum said: car model:daihatsu charade aura is there any DIY method to fix this instead of replacing a new water pump? Click to expand... normally chabging to new water pump...donno that this item can be service or not....
nyantong Known Member Senior Member Oct 7, 2012 #3 Firstly, where is it leaking from? If its from the gasket seals around the water pump body, you can use rtv sealant to re-seal the water pump. However, if it leaks from the pulley bearing, I'm afraid you will have to change the entire pump.
^pomen_GTR^ 7,000 RPM Senior Member Oct 8, 2012 #4 just change the waterpump if the pump already leaking....
spoon civic Known Member Oct 8, 2012 #5 ^pomen_GTR^ said: just change the waterpump if the pump already leaking.... Click to expand... yezzaa...........afraid after servicing the problem occured again..
vr2turbo ((( God Level 30,000 RPM ))) Helmet Clan Moderator Oct 9, 2012 #6 Once water pump starts to leak better change. Work to take out also will take time....
