Karat On My Car....
trueno
1,500 RPM
about one month oledi....my sis drove the car and scratch to da wall....now,some place already karat...what can i do??respray whole car??no money leh...all sifu..help me please... :(
i think what a workshop will do is sandpaper is till the rust is gone, then a layer of anti-rust, then maybe the paint. I'm planning to do a part of my roof too. a big spot has oxidised due to bird dropping. :angry:
..my fren's wira last time send to workshop to respray that car roof,coz got few spots of karat(quite serious),cause by rain,...but after few month the problem coming again...we dunno why... ;)
i think it depends on how they do it. all the steps taken. i think the best is..
they sandpaper it down till a smooth surface. then put anti-rust paint or treatment, then primer(dunno the spelling) paint b4 putting the last paint on top...
Hopefully someone can come up with an answer as well... i'm also looking for an answer.... i hate birdshit! :angry:
In my area,
1) Most young and lazy body mechanics
- they want short-cut, so, they will just sand paper it off and apply antirust and body clay
- respray it and it's done
- it'll come back in a few years time
2) Old and hardworking ones
- they will strip off the ceiling of your interior
- then grind off the whole roof to check for rust
- drill onto the place that there's rust if it's a spot or take that whole piece of rust out
- if it's a spot, they will fill the hole by putting solders 'timah' that they use to put on electronics boards
- if it's a piece, they will replace the piece with another new piece that they bought in a roll. Make sure the material is good and not thin. Normally, it's alluminum.
I sent my old car to those old fellas and they need 2 weeks to finish it. The result is perfect and the cost is a bit expensive. Worth it! :) but i sold my car. :(
ken12292703,
thanx for the info. mind telling where it's located at? and how much would the job be? for a whole roof, satria. sounds good.
I am in Seremban
Their workshop is under a big tree with some old huts
The price is around RM300 to RM500 for the roof depends on their mood and the cars they have. Without paint spray. It might be cheaper if it is not very serious.
They are only two old bird body mechanics working.
They are very friendly. :P
no man...dun send ur car to lazy buggers...karat is like a tumour for ur car....if one panel kena sure later on the other part kena one...so best if u could change rather than sanding/cutting the affected part....last time my iswara was full of karat...send to one bugger and he just cut the karat and weld new one....a few months later karat again...diu...now i just change the whole roof and the door skin :)
You are right SataniC.
They will change it if it is too serious.
Good mechanics will think for your pockets sometimes. :)
Bro, the rust on proton cars especially the roof is due to the silicone the original manufacturer uses. The silicone eats into the layer of coating on the metal and when the silicone becomes loose it starts to rust from the inside out to the top of the roof. Bird shit is acidic too but most of the proton cars have this problem and normally the best solution is to change the roof sheet. No matter how u sand and spray anti rust at the spot also no use coz it is from the inside. That's why when ur car is new that's the best time the take the silicone off and pump in good type of silicone but it is something we....i mean i wouldn't do coz..lazy lah... :lol: .correct me if i'm wrong but to my experience that is the case coz my friends car also got the same problem. Cheers!
Originally posted by KP61+May 23 2004, 10:25 PM-->
QUOTE (KP61 @ May 23 2004, 10:25 PM)
--QuoteBegin-FuGZ
Bro, the rust on proton cars especially the roof is due to the silicone the original manufacturer uses. The silicone eats into the layer of coating on the metal and when the silicone becomes loose it starts to rust from the inside out to the top of the roof. Bird shit is acidic too but most of the proton cars have this problem and normally the best solution is to change the roof sheet. No matter how u sand and spray anti rust at the spot also no use coz it is from the inside. That's why when ur car is new that's the best time the take the silicone off and pump in good type of silicone but it is something we....i mean i wouldn't do coz..lazy lah... :lol: .correct me if i'm wrong but to my experience that is the case coz my friends car also got the same problem. Cheers! [/b][/quote]
KP61,
thanks for sharing, will keep that in mind. :)
yalor, no use one..save money to change whole roof
Just plan change my satria roof few week ago,
roof from chopshop (RM380), labour(RM650), paint (RM300)
<_<
Originally posted by Dremel@Jun 2 2004, 05:59 PM
whoa.. labour RM650 ah GTR2579 ? where's the location of the workshop?
:( dremel...guy, any suggestion..i think ask more workshop later..
... roof bought already from chopshop....workshop location seapark, pj
