Interested with SW20 Turbo :)
kkyen
Dear MR2 owner, I'm looking into JDM Sport Cars... and finally get in love with this MR2 SW20. Well, I need some information before getting it :)
1. How to differentiate 225 and 245 version of SW20 by just viewing the engine?
2. How is the maintenance of SW20 Turbo? Any common problem?
3. What should I check on the car before buying it?
Lastly any stock MR2 SW20 turbo selling?
Thanks Guys!
Displacement, cc 1998
Engine model 3S-GE
Max.power (Net), kw(PS)/rpm 200 ps (147.10 kw) / 7000 rpm
Max.torque(Net), N*m(kg*m)/rpm 21.0 kg*m (205.94 N*m) / 6000 rpm
Power density 6.2
Engine type Serial 4 cylinder DOHC16 valve
Engine information VVT-i
Fuel system EFI (electronic fuel injection)-L
Turbocharger No
Fuel type Unleaded premium gasoline
LEV system (Low emission vehicle) No
Compression ratio 11
Bore, mm 86
Stroke, mm 86
Final gear ratio
Fuel consumption at 10-15 modes, l/100km 8
Engine model 3S-GTE
Max.power (Net), kw(PS)/rpm 245 ps (180.20 kw) / 6000 rpm
Max.torque(Net), N*m(kg*m)/rpm 31.0 kg*m (304.01 N*m) / 4000 rpm
Power density 5.18
Engine type Serial 4 cylinder DOHC16 valve IC turbo
Engine information
Fuel system EFI-D (electronic fuel injection)
Turbocharger Turbo with intercooler
Compression ratio 8.5
Bore, mm 86
Stroke, mm 86
Final gear ratio
Fuel consumption at 10-15 modes, l/100km 9.4
Engine model 3S-GTE
Max.power (Net), kw(PS)/rpm 225 ps (165.49 kw) / 6000 rpm
Max.torque(Net), N*m(kg*m)/rpm 31.0 kg*m (304.01 N*m) / 3200 rpm
Power density 5.73
Engine type Serial 4 cylinder DOHC16 valve turbo
Engine information
Turbocharger Turbo
Compression ratio 8.8
Bore, mm 86
Stroke, mm 86
Final gear ratio
Fuel consumption at 10-15 modes, l/100km 10
