my car begin to go crazy.,.,
sometimes.,., when i put R.,.,
it take 1-2 second to switch.,.,.,
N blinking then only R.,., any advice.,.,??
please.,., can call me or pm me.,.,
0173747222.,.,
maybe is your smt ecu got problem~~~~~~ u is 5 speed or 6 speed ? and your smt oil pump is how many kilo meter change smt oil ? u open door time the smt pump got run or not? or the smt pump run time sound like jam ?
a got a call from JB friend and gimme some tip on smt.,.,
i dunno have to wait smt pump when open door.,.,.
now i know.,., seem ok now.,., so far so good.,.,.,
alot of workshop only use brake fluid or they think its ok. but...
Failures of SMT are usually;
1) Accelerator Position Sensor failure
2) Pumps, accumulators go bad and/or spring leak. HPU (Hydraulic Pump Unit)
3) Other sensors or switches can go bad, or the contacts on a switch can get dirty
4) Wiring or TCU -- wiring can go bad -- loose connection, dirty contacts.
5) Relearn needed -- change a clutch, etc -- the TCU may need to relearn the base sensor position readings. Best is to go to a dealer and ask they initiate a relearn using the OBB-II diagnostic tool.
I'm not SMT pro, just can goggle or search this on spyderchat
