Help on Alignment setting?
wsonny
bros,
I did my alignment last week before i drive down to JB, after i reach JB my alignment run right side again n my steering lean aside also.... izzit the foreman did not tighten up any screw or any problem on my setting.
bros,
Well, safer to get it checked again, since there is a problem.....
For alignment they only adjust the tie rod end, so just check the nuts at that area. Will have two nuts, and one is a lock nut and if both are locked together they are still intact.
