Head Q's
synail
Hi guys,
Before sending the head for machining
do I need to clean/remove the sticky oil leftover?
Do I need to take out the valves?
I lap the valve after the machining process...rite?
When you say machining I assume you mean skim the base and PNP job? As long as you're careful with the skimmed surface, it doesn't matter which you do first. Personally I did the valve after the skimming. I also did a few other small things like powerlynz which needs to be machined on the valve itself which explains why I didn't lap the valve first. Then there was the Singh groove.
All depends on what it is you wanted to do la.
I jez finished cleaning the head...i just need a common head job.....its a 13 y.o. motor...1st time diy
PNP = smoothing the intake port rite...1st stage?
---------- Post added at 11:49 AM ---------- 6 hour anti-bump limit - Previous post was at 11:35 AM ----------
Is this considered clean? The diy is way off schedule..
Hey you guys were rite
Petrol, diesel and kerosene works
And its raining heavily...
Rain = 10
Me = 4
---------- Post added at 03:30 PM ---------- 6 hour anti-bump limit - Previous post was at 03:23 PM ----------
Since doing porting already why nothing the exhaust also?
Actually.... I'm not familiar with pnp
