Falken FK510
Why not just use 245/40/18? Much cheaper and common size, closer to the front 225/45/18 and better fit for 8.5j rims on your F30.
boss
https://tiresize.com/comparison/
225/45 R18 fronts
255/40 R18 rears
are identical in diameter
245/40 R18 will be 7mm less for the rear...
2 front 1 brand, 2 rear another brand is okay. I use many times like this when changing brands.
I check a few shops, Falken some at 800, 730 cheapest. One shop no Falken say PS4 810, that is why I let you know......lol
You got PM boss. I think rear got better traction is safer. They say new tyres go rear.
boss
225/45 R18 fronts
255/40 R18 rears
I know diameter wise it's slightly smaller but width is closer so less understeering tendency. Anyway 8.5j also better match fitment with 245. I'm also now using 225/45/18 & 245/40/18.
FR setup naturally oversteers right? I kinda like the way my car handles now.. a bit of throttle it will still oversteer..
So far so good. Wear still ok. Did a few braking, stops with plenty of room left. Wet also good so far, I only have experience with PS3 and not the PS4, FK510 is definitely just as composed as PS3 in the wet, I have confident and feel safe with it.
Should be the 3rd Falken model quite highly recommended. Those days was the ST115 model, then the Ziex ZE-912, but this model later failed. Now the FK510 seems to be making a comeback for Falken
Well no more sweet rubber smell. Run in well. Tyres are doing well, no uneven wear, I must have hit some pothole somewhere both front and rear right rims bent... had to repair, lucky tires are fine.
Consistent, no complaints and I am gradually pushing them more in the corners.
I think at the price, I will definitely give it 5/5 rating. Don’t compare with PS4 please, if you’re willing to pay ~40% more just buy the PS4.
How does one hit potholes with rim denting impact without realising it? Tummy upset again?
Exactly, I used to use Yoko S-Drives. Friend say PS2 better, I say I know but I don't drive to PS2 max standard, where S-Drive can handle about 80% of PS2 but cost almost half only during that time.......
