Cleaning MAF
Hey guys, just an update. The MAF is very delicate....be careful when cleaning it. One of the best solutions is Brakes Parts Cleaner.
It comes in an aerosol can and is very effective, because it cleans but is not too harsh and it also doesnt leave any residue or sediment. I have tried it on a RB20 MAF...works like a charm! When u unplug it from the connector, check and clean the contact points wth ctc point cleaner and scrape of any oxidation...then just use the brake part cleaner and spray straight thru the MAF...let it dry, then plug and play. Hope this helps. Cheers! B)
you guys should use CRC carbon cleaners , its more likely to clean carbon in the carb's , throttle bodies , pcv valves and you can spray some in the spark plug hole and let it sit for a few hours and then rev it up . I use this CRC to clean my MAF and you can really see the dirt coming off from the bee's nest :lol:
