Can The Spare Tyre clear 6 - pot caliper
wheels
Sifus,
wanted to find out if the spare tyre would clear the 6 pot front caliper in case of emergency??
If not, is there any alternative??
thanks bros.... noob here
Assuming you have a front flat tyre, in most cases (unless you also have big brakes in the rear or too wide a rear wheel) you can move the rear wheel to the front and mount the spare to the rear.
so you'd be removing 2 wheels instead of just the affected wheel. hope this helps
