Brembo Brake For MRS.
Re: Brembo Brek For MRS.
Efendi_njang
the master mr-s cylinder should be able to cope with 4 pot.
too large of brake kit in the front will interfere with the stock size mr-s rims.
you can get someone to fabricate the adapter but need to ensure the calipers can match the rotors.
not my car....my cousin car actually....he want to use brembo brek for his car....
now,he use 19" sport rim on his car....
hehehe.....
can anybody has use BBK for mr-s...dont mind wat brand,s long s,good quality......
thx for reply......
there is a Lotus 4 pot front brake & easily adaptable without changing/custom a the bigger brake pump (which if not dont correctly may leak or worse case senario car is worse off) by one of mr-s owners.
i'm having a original brembo 4 pot with rotors in my car. (not customed) & was discontinued by brembo as many felt its too expensive & stock brakes seem to be able to cope with it.
of course & unless you ride has been slapped with alot more powwer,......:driver:
