boost meter wiring
lan evo
3,000 RPM
just bought a boost meter,there was 3 wires one black,one red and one yellow.where the yellow wire should be connected?
Can't find it on ur instructions?
May be red to 12v terminal
black to ground
yellow to ur low beam?
That's my guess. Try at ur own risk :P
yep, power is red, ground is black..
yellow is dimmer. like what eric says, bascially when u on ur lights the meter light also becomes dimmer.. cos at night ppl dont' want it to be too glaring what. :)
i try to fix direct to the battery terminal without connecting the yellow wire.only the needle of the meter illuminate the el background didn illuminate.
when there is EL, there will be a box outside and a different adaptor...
EL there will be external inverter. small cube box.
oh u didn't mention it's EL.
Yes like wat he said ^^^ there should be a control box..
