Anyone Wanna Join Me>>push Start Button
u better recheck all ur wire..ur relay wont kong so easily one..
proton ignition is yellow strip...starter is white strip....
follow the relay diagram wriitten on ur relay...
Ok bro, let me double/triple check the wire..TQ very much. ;). I follow the diagram below, the one that hv been post before.
http://www.imagestation.com/picture/sraid55/p057c148d9ef2708b95ca31a5e9c2c2e4/fc806c86.gif
This is the URL-->http://board.accordtuner.com/showthread.php?t=1476
Originally posted by ksgoh+Oct 6 2004, 08:19 -->
QUOTE (ksgoh @ Oct 6 2004, 08:19 )
--QuoteBegin-Indecided
@Oct 5 2004, 21:00
relay and wiring, fuse
where u get the transparent insulator?? what is it called? [/b][/quote]
no one??
e-mad...yup correct...u can follow the diagram...
check ur power supply to ur relay working or not..make sure everything is connected......and where u tap ur dc12v?
escaflowne, dc12v??emm...izzit same to constant 12V wire? I'm follow exactly like diagram above (wire 4), the one that connect to fuse. So, what you think? :)
ksgoh, if I not mistaken its call 'connector insulator'....better print the pic below and show them what you want....easy as that. :D
http://www.zerotohundred.com/forums/uploads/post-41-1096981242.jpg
indecided>>yeah the constant 12v..i called u yesterday for the button thingy....really interest for it to illuminate...can u tell roughly any diff regarding the connection for the illuminate push start button???it need another constant 12dc???
mine some time it jus 'tek tek tek' when i push the start button, but i'm using without relay. jus connect the starter n ignition to the button....
wat's the problem?
Heys escaflowne and ksgoh,
the connector insulator? No idea la. Supplier supply to me with wiring together. But if i'm not mistaken you should find it on Jalan Pasar..
esca, yes.. there is an additional 12V for the lamp. just tap tht to the common wiring la..have to run additional ground only. the 12V tap from ignition..the switch la...when on also on :)
Originally posted by wira_auto_stendet+Oct 12 2004, 12:21 -->
QUOTE (wira_auto_stendet @ Oct 12 2004, 12:21 )
--QuoteBegin-ksgoh
@Oct 9 2004, 17:56
refer the previous page(s)...
ok..but still don't know where to start la...from scratch..maaa..... [/b][/quote]
good luck....
thanks Indecided....will try to find at hardware shop....i dunno where is jalan pasar...:P
actually i'm from northern.....since i have been pudu/times square....i think i able to find it when i get there....
