Altezza gear box problem
2slow
3sge beams engine.Running with toyota T-IV ATF oil
car won't move when cold start in D. but works with reverse. Have to wait till temperate reach certain level then D will move.you guys face this type of problem before ? Pls guide
Sounds like some solenoid or valve problems. Not sure if adding some lubegard will help, but many seems to have pretty good results. Also check whether the lubegard works with T-IV atf or not, as most are either on SP III or Dexron III
Bro...have u try gearbox additive?
J.B brand in yellow can quite good in hard/rough shifting gear engage mostly in d morning.
Try n c.oso pour d orange can J.B gearbox treatment to soften seals.
