Aircond Service
cyful
My car has clock nearly 300,000km, nearly 8 yrs.... never once i do aircond service. Should i be worry as the aircond still good ?
If you do a good of keeping your carpets clean, the aircon filter clean, refresh the aircon gases and change the valves, then you should be good to go. No problem don't touch is my belief for aircon.
I thought you new school, service every year......hhahahhah
---------- Post added at 04:22 PM ---------- 6 hour anti-bump limit - Previous post was at 04:20 PM ----------
I am old school and if your air con is still running fine, leave it. With 300k km and 8 years, there may be some corrosion on the cooling fin unit and if you take it out to clean, might just puncture it.
just add some oil to the compressor.
if u are willing to spend more then vacuum the system before putting the new oil.
i learn from bad exp of not adding/replacing the compressor oil.
