7 Gen Fuel Pump
lots of 2zz are running on emanage, especially the emanage ultimate. I've seen evidence of the same problem where the stock ecu will revert it back. It all depends on the tuner... if he knows how to tune it in open loop and close loop..... hard to explain here lah.....
camcon is not very precise when it comes to tuning... it can alter your vvt and fuel setting..... but the tuning is base on rpm break points only. It doesn't take into consideration your load;if it's low/mid/high load at each break points.
shaharel...
u can try using this dynojet power commander III....
RM1700 include dyno tuning....]but...
not so famous in the market......:biggrin:
so far .. i m using tat..dun hv any prob...
Power FC is a standalone ecu... it's not a piggyback... you basically have control of everything over your ecu.... emanage alters fuel trim and ignition timing only....
you would wanna tune your vvt and also have control over your LIFT change over, idle rpm, speed cut, rev cut, etc..... Power FC does all this....
Power Commander??? :smokin:
