2006 Range Rover Rims & Suspension System Problems
Rahman77R
A few hours ago while driving my boss's Range Rover I noticed a malfunction on the suspension system. I set the suspension to it's highest position but after driving a few hundred meters the suspension lowered itself automatically to it's default position. Does anybody on ZTH know any mechanics or workshops that specializes in Range Rovers?
Also looking around for a set of rims to replace the dented 22" X 10JJ KAHN Design RS rims that came with the car. Having trouble finding 22" rims for Range Rover. Any recommendation on tires & rims shops?
Could it be these?:
- The air suspension can't drive on the highest position for extended period?
- You have a leak?
are there any errors displayed?
Try Hup Shun in Sunway. Not sure if he has 22" rims, but seen many huge rims there. Probably need to order if don't have....:driver:
Dented rims can fix..depends how bad..
Lowering itself, were you travelling at high speed? And the car lowers itself for aero purpose?
maybe this will help
OFF-ROAD HEIGHT
Off-road height can be selected when the suspension is currently set to normal height, at any vehicle speed up to 70 km/h (43 mph). Press the up-arrow button on the electronic air suspension system controls. A confirmation message is displayed in message centre. See ELECTRONIC AIR SUSPENSION CONTROLS.
The off-road height setting is dependent on the vehicle's speed. The current off-road height setting is confirmed with an Off-Road (1) or (2) icon displayed on the touch screen, when the 4x4 info menu is displayed. See TOUCH SCREEN HOME MENU.
The Off-Road 1 height is 40 mm above the normal height setting, up to a maximum vehicle speed of 80 km/h (50 mph). The Off-Road 2 height is 75 mm above the normal height setting, up to a maximum vehicle speed of 50 km/h (31 mph). The suspension height can change automatically between these heights.
The Off-Road 2 height can be manually selected when at Off-Road 1 height, at any vehicle speed up to 40 km/h (25 mph). Press the up-arrow button on the electronic air suspension system controls.
To manually select the normal height suspension setting, press the down-arrow button on the electronic air suspension system controls. Alternatively, increase the vehicle's speed above 80 km/h (50 mph) to automatically set the suspension to normal height.
http://www.ownerinfo.landrover.com/document/LK/2016/T23339/18682_en_GBR/proc/G1800407
OFF-ROAD HEIGHT
Went to Hup Shun Sunway last weekend. They told me for Range Rover 22" rims it would have to be ordered. My boss nearly got a heart attack when I told him the estimated price for 22" Range Rover rims which was RM20K+ including landed cost.
Could it be these?:
- You have a leak?
Hi Tom, a lot errors displayed on the meter. Will try to take some pictures of the errors displayed.
Yup, remember 20" already way into 5 figure region, some more yours are Range rover's ones.....:driver:
